Hello, I had a idea for a car in my yard I have had for a while. It is a 1983 7 series BMW. This is still a very sturdy car just not had a want to work on it. I think it is a fuel system issue. This car is a automatic and I have considered setting the transmission up for electric motors like the gm 700r4 but considering it is a bmw and the rarity of parts for such I believe my best bet is to run straight to the rear differential with the motors. I am wanting to use 72 volt motors three of them and daisy chain the power lines from the controller with a double throw contacter so I can have reverse. I am sure a 9"motor will fit where the transmission and drive shaft once set so room is not a issue. This will leave the engine compartment wide open for batteries and electronics along with room where the gas tank once set which is by no means a economic sized one. My goal is to have 300+ mile range and a charge time of less than 8 hours with a top speed of 80 miles per hour. I dont know exactly what the gear ratio is or the specifics on the electric motors I am getting all I know is gas is almost 4 dollars a gallon here and I have a thirsty truck with no way to afford to buy a smaller car to save gas. Any help or advise would come in handy. Yes, this is my first build. I have a motor cycle chassis I am wanting to cut my teeth on if I can get a title to it. Thanks in advance for the help
