I'm a student trying to learn about Electric Vehicles. I need to know what an Shunt is, in plain English so I can understand!!!!! ((Not a Shunt Motor))
A shunt is a very low value calibrated resistor. Its purpose is to measure the current that is passing through it. And they are generally specified by a current and millivolt rating. A 1000A 50mv shunt would have a resistance of 0.00005 ohms (0.05v/1000a). If you run 1000 amps through it the voltage across the sensing terminals would be 0.050 volts. In the case of this example if you read the voltage across the terminals you divide by 0.00005 to get the current.I'm a student trying to learn about Electric Vehicles. I need to know what an Shunt is, in plain English so I can understand!!!!! ((Not a Shunt Motor))
