21 - 40 of 72 Posts
· Administrator
Wonderful!
In the first video they did mention batteries - but it was something about the supercaps not being able to retain charge for a long time so the batteries somehow fixed that
The core of this is still the super cheap super small supercaps
I do hope that they actually do exist
I wonder - maybe the 3.6 kWh on the box is the actual storage capacity - BUT with it configured as a battery you can only use 1.2 kWh
Which would tie in with lead acid batteries where you can only use a fraction of the capacity
Or even Lithium where you can only use 80%
Discussion Starter · #23 · (Edited)
...".And the latest reply from Arvio commenting on the Patent " battery" reference... ????????
Post by Supercaps » Today, 17:22
Yes the patent covers this. Patents are normally written as broadly as possible to prevent copying methods by other parties. This is why the words “in some embodiments” and “can” are used. There are no lithium ion electrochemical cells in the super capacitor modules which are being used. Good to see you doing your research. Have you worked out how it’s done yet?...
Suggesting the patent is bit of commercial deception ?
That's the scheme in which a small battery is used to charge the capacitors as necessary to maintain some minimum level to avoid damaging them. It's not meaningful to storage capacity, but the inclusion of electrochemical cells in a system claimed to have none is disturbing.
Then the 3.6 kWh claim is meaningless crap. If someone owes you a hundred dollars and gives you a box containing a hundred dollars, but you can only ever actually get ten bucks out of it, does all the extra money in the box do you any good? Do you feel ripped off?
Even a lead-acid battery can be discharged to the full depth of the rated capacity... it costs in cycle life, but the voltage at the end of discharge is still close to the nominal and usable. At even 80% depth of discharge, this "48 volt drop-in replacement" which must be charged to 54 volts to be fully charged is down to 24 volts; that's not useful.
Claiming that the design is covered by a patent then sending that "Have you worked out how it’s done yet?" response from Supercaps about the patent would be suitable for someone attempting to insult the recipient as much as possible. :eek:
If I were a potential buyer, I would quite bluntly tell them where to stuff their patents, and to get back to me when they have decided to communicate professionally and prove their claims.
Yes, patents are often filed for any design which can be pushed through the patent processes (which is just about anything now, since patentability no longer requires that the idea be novel, non-obvious, or even workable) and might at any time be used. It's not deceptive, it's just covering all the bases (even possible product names are trademarked although they might be built)... until the company says that the product is as described in patent and then says "gotcha, it's really not". :mad:
Discussion Starter · #26 ·
OK,.. More feedback from Arvio..
Post by Supercaps » Today, 01:45
Just to clarify a few things. The super capacitor in the picture is one of the range of super capacitors, not the one in the 3.55kWh unit. Secondly the calculations are correct except for the micro farad typo. The missing piece of the calculations is understanding of the technique used to extract almost all of the energy from the capacitors from 54VDC down to 44Vdc when in series without a series DC to DC converter. Yes there are electronics involved. The electronics perform high speed balancing between the parallel cell groups. This is the IP of the product. You can learn about this by reading the patent. The real test is at the terminals, which can easily be shown to deliver the energy stated. The unit can be shown opened up to anyone interested in person to have no electrochemical batteries and proven with a colomb meter to be what is stated. Still haven’t had anyone from this thread come to visit. Doors are always open. Nothing to hide......
Minor point Brian, but he didnt say there was no dc/dc conversion......he actually said there is no "in series". dc/dc conversion !
In parallel would make no sense. Weasel words don't give me a lot of faith.
Now that may be nothing ,..or it may distract from the fact that there could be some cell level conversion trickery,.
That previous photo with the blue supercap bank showed a lot of cell level electronics.
My guess is that's the cell monitoring, and charging (from electrochemical cells!) at extremely low voltage.
I suppose it's also possible that the entire unit is reconfigured to half as many cell in parallel and twice as many in series at the low end of the cell voltage range... but then why not just say that?
With regards to the voltage range, a typical 48v lithium pack (13 S of 18650s ), would typically have a full capacity range of 39-55volts ( 3v - 4.2v per cell) .
Good point, but that full range is not typically used, and the lithium voltage range is much narrower for a very large fraction of the full capacity... and vehicle manufacturers routinely state both a nominal (full voltage range) capacity and a usable capacity.
This reminded me of a previous "ultracap" discussion...
Anybody remember the "fastcharge" 1000 hp drag bike thread ?..
http://www.diyelectriccar.com/forums/showthread.php?t=178345&highlight=1000+drag+bike
What happened to that project ?... Their blog is gone and the site is "dusty"
I skimmed through that discussion... yes, very similar.
So, rather than DC-DC conversion "in series" with the capacitor output, they are presumably pumping the remaining charge out of some cells in a normally parallel group to the rest, probably in stages.
Man, it would have been a lot easier to have just said that. :rolleyes:
Someone with the patience to read their patent while mentally deleting all of the non-applicable parts, and keeping in mind that patents are intended to describe rather than explain, can see if that seems reasonable.
All of the electronic bits - the patents and the "secret sauce" are almost besides the point
To me the point is the 200:1 reduction in weight and the 1000:1 reduction in costs
I agree with Duncan, I think the way it works and stuff doesn't matter (at least for now). if they can prove the weight and cost, then it becomes a viable product. if not it's just another product that will not see the light of day outside of exhibitions
Not graphene this time but a superelectrolyte and stainless steel with a special sauce:
http://www.greencarcongress.com/2018/03/20180319-rr.html
Could be the next one with 180Wh/kg.
Big name is involved: RR as in jet engines and luxury cars.
The Rolls-Royce engine and automotive companies have been unrelated for decades... but yes, Rolls-Royce is a major and very capable manufacturer of turbine engines for various applications. That's a good thing due to the technical resources which will be available to the project, but the purpose is still to "explore the potential" of the technology.
Discussion Starter · #33 ·
Remember... Whilst they are "exploring the potential"...the Kilowattlabs guys claim they already have supercaps with 2-3 times the energy density of the units in the Sirius device !....
....which would put them in the 300Wh/kg range ,...if true.
· Administrator
Interesting
So 8.5% at 44v and 95% at 53v
Just don't see how you do that with Supercaps unless you set the "zero" at 40v
So if 2.7v is full then "zero" would be 1.9 volts
Maybe that is how they do it - it's actually a 12 kWh pack and they are only using the top 3.5 kWhs
· Administrator
I think that it is much more likely that they are only using the top 1.2kWh and that the 3.5kWh is a true but irrelevant capacity
Either way those capacitors (if it's all true) represent several orders of magnitude improvement in price and in density
Lets say that they do work - and the cost is what it would appear
With some additional electronics to actually squeeze the energy out (DC-DC) they are almost at the power density to put in a car - with effectively infinite life
So carry twice as much battery weight - but your batteries last forever
Or for use in power storage where the weight is not important but the ability to be cranked up and down three times a day - 1000 cycles per year - 40,000 cycles across a 40 year life could well be vital
If these things actually exist at those prices this is a game changer
Discussion Starter · #38 ·
OR...if they really have figured out how to get most of the energy out (8.5% remaining). Whilst holding the pack voltage minimum at 44v , then it only needs to go up to 55.5v (2.77 per cap) to hold the full 3.55 kWh. ???
So we are back to the issue that They would have to use some form of voltage boost that is not dc/dc as we understand it ?
We seem to be going in circles.
Interesting
Right - that's how capacitors work, and what I've been saying since post #2 and first quantified in post #13. Either most of the energy is not coming out, or the caps are going down to a much lower voltage (1.9 volts if they're all in the same state). There is no other option in the real world.
Okay, but in the statement quoted in post #26 the distributor explicitly said this is not the case.
It's just not DC-to-DC at the place (point in the power flow) where we expect it... which they call "in series", because we would expect the output of the capacitors to go through the DC-to-DC converter to reach the load.
As I suggested earlier:
So the cells which get nearly fully discharged are taken down to much lower (well below 1.9 volts) voltage by DC-to-DC converters which add that energy to the remaining cells, which only get down to 2.2 volts (for a 44 volt series bank). They call this "high speed balancing between the parallel cell groups", although I think to most people familiar with complex batteries "balancing" means the very opposite: equalizing state of charge, not deliberately shifting charge to a selected group of cells.
Thoughts on this likely implementation, and the cost, particularly in efficiency? Is it worthwhile compared to running the entire output through a DC-to-DC inverter (given that either scheme would only be necessary once the caps drop to something like 2.2 V each)?
Discussion Starter · #40 · (Edited)
The guys on the AEVA forum have the most likely explanation ..
http://huahuienergy.m.manufacturer....ttery/1152403017/Lithium-Titanate-Battery.htm
LTO cells , 18650 size, 1.8 - 2.75 voltage range , 1.3 Ah capacity (3.1Wh)
Looks like the vague pictures we have seen from Arvio and fits with the 20s, 60p, pack size they have confirmed.
But it does call a lie on their claim of "No lithium electrochemical cells "
But the Arvio guy (Paul Wilson) is obviously totally convinced that he is dealing with Supercaps !
He goes into some detail in this latest video.. ..from about 8mins in
https://youtu.be/fdI1ZpRhUkI
21 - 40 of 72 Posts
