I've been using the software written by Damien, Colin Kidder, and mostly Tom Debree. I took a copy of the software so that I could configure it to work with the control scheme in the TesLorean (i.e. all stop/start charging commands come over CAN).
My setup
- EVSE (240v 40A)
- Battery currently at ~365v
- Attempting to charge to 400v
- Singlephase
- currReq (current request) limited to 10A
I've tested with the modified version and the version from Tom's github, but I'm getting the same set of symptoms when attempting to charge...
1) DC total Cur:0.09 and stays at a very low value?
2) AC current reports as 0 for modules 0 and 1, and 0.53 for module 2
3) The charger appears (clicking relays and lights) to start, but after 2-3 seconds the modules click off, the EVSE relays click, and then the modules switch on again. If feels like the modules are resetting after a few seconds but it is hard to tell.
A couple of questions...
EN ? - Is this 'Enabled' (as in the module is enabled?)
Flt ? - Is this a Fault flag?
Stat ? - Status, any idea as to the meaning ?
Thanks
Jeff
PS. Attachment "July 8th 338pm Stock.txt" is the serial debug log from the software from Tom Debrees' github. The other attachment "July 8th 250pm noAuto.txt" is a run with the software I modified (autoenable is switched off in this run).
My setup
- EVSE (240v 40A)
- Singlephase
Thanks
Jeff
