I've been working on converting a 1977 VW Rabbit with a 4-speed manual transmission for the past 3 years. Here are the specs:
I'm well aware these batteries do not continuously provide the ~650A this motor needs in order to achieve 108lbs/ft of torque. According to the motor controller, it has drawn a max around 430A, which already seems off. The battery output is rated for 1000A for 10 seconds, so I wouldn't think they're the problem, and the motor controller is rated for 650A. According to the BMS, the batteries are in good condition, so even if I were to get 500A for 10 seconds, I should still be able to accelerate faster than I do now.
Is there anything that might be limiting the power?
- AC-20, since at 96V it has a little less HP than the original 1.6L engine the car came with.
- I'm using 4x Tesla Model S batteries in series, which gets to about 94v fully charged.
- Curtis 1238E
