that looks very interesting. One questions about the heaters: It was my understanding that Lithium batts weren't as affected by cold as LA; do you think the battery heaters will make much difference?
Yes. According to the SkyEnergy spec charging is above 0 C or 32 F. Dave at evcomponents told me it is difficult to charge the cells at low temperatures, and they only take about a 60% charge at around 30 F. Night temperatures where I live are many times in the twenties (F) and sometimes around 5 F. The heaters are powered by 120VAC. The plan on cold nights is to plug them in prior to charging with the thermostat set to around 60 F and turn on the charger when the sensor gets to about 45 F - hopefully in an hour or so. They will be off the rest of the time. The temperature sensor is bolted to the battery clamp on one of the set of four cells in the front box. Each heater, which heats about 4 cells is only 35W, so will provide only gentle warming. I'm hoping that the insulation, small amount of heat generated by the cells during vehicle operation, and daytime temperatures typically above 35 F will keep them above 50 F or higher the rest of the day. One problem will be equalizing temperature of the front box with they other two since it is exposed to more air flow when the car is moving. I'll see how this setup works, and modify if necessary. I can add insulation to the outside of the front box. During summer I'll remove the front box top for cooling, and I have a 145 cfm bilge blower to put a bit of air through the other two boxes. Have to see if it requires more. Have to start somewhere and gather data.It was my understanding that Lithium batts weren't as affected by cold as LA; do you think the battery heaters will make much difference?
I am using the Voltblocher shunt regulators with HCV and LCV signals made by Brian Blocher and purchased through evcomponents. I plan to use the HCV signal with a circuit being made by evcomponents to throttle back the PFC30 to about 1A output (been waiting for this for a couple months now though, with no response to my last email sent a couple weeks agoI hope a BMS will be involved to protect your battery investment.
I used the equation from Bob Brant's book that gives rolling resistance as a function of vehicle speed, but of course that is some rough average. It may overestimate it, as I seem to get conservative numbers for range compared to what Brian Blocher and Dave Kois have posted for their vehicles under "ev performance" on this forum. I also don't know the actual Peukert exponent for these cells, and just used 1.02 as an estimate. However, to match their numbers for range I have to set the Peukert exponent to 1.0, and unrealistically reduce the drag coefficient and vehicle weight for their vehicles. I don't understand this. Range numbers are very difficult to interpret as many times the average speed and DoD are not reported, and average grade and whether the path was a closed loop is rarely reported. The drag coeff for the Swift was given as 0.32 and I just roughly estimated cross sectional area from a few measurements.If you get the rolling resistance and aerodynamics dialed in...
Have you tried emailing James directly? He's usually good about responding.I plan to use the HCV signal with a circuit being made by evcomponents to throttle back the PFC30 to about 1A output (been waiting for this for a couple months now though, with no response to my last email sent a couple weeks ago).
Have you tried contacting Manzanita and seeing what is required?If I can't get a circuit from evcomponents, I'll have to determine the input signal to the PFC30 Regbus that is used to throttle back the output based on thermal input and make my own. Anyone familiar with this?
Turns out Dave didn't receive, or didn't see my email. He said he will check on progress on the circuit and also have someone there send me info on pin outs for the regbus (some techs there also work at Manzanita).Have you tried emailing James directly? He's usually good about responding.
Yes. Rich told me to short pins 1 & 3 to shut down the charger - I think. Been a while. I was just fishing for info from someone with experience. I expect I'll get the info I need from evcomponents. If not I'll contact Rich again.Have you tried contacting Manzanita and seeing what is required?
I would think it could be a real problem if you are inching up to a pallet or near a coworker, but dunno. I see a lower priced potbox is a bit of a quest on your part (posts on the soliton thread)A noisy pot probably doesn't cause much problem in low speed forklifts.
Yeah you got meI see a lower priced potbox is a bit of a quest on your part (posts on the soliton thread)We all have our pet issues...
If price is an issue, then using the stock one on the Swift would seem to be a cheap solution....Yeah you got meI've struggled with the potbox issue for a while, going back to my AMPhibian build. I ended up with this one and have had no issues with it, very fine control http://www.cloudelectric.com/product_p/th-bz31686.htm
I've even toyed with adapting one of them for my car build. I realize it's an important piece but it should also be a simple and relatively inexpensive piece, at least in my mind. I should let it go, I'm obsessed![]()
