1 - 2 of 2 Posts
If you want to always set up the head display each time you start up then go ahead with the mess of relays for each remote. Maybe you don't have the current sensor so this wouldn't affect you. The current is really quite small and I never had any problem with out of balance batteries because of it. I had flooded lead acid cells.
If you are using Lithium type cells and do not top balance your cells on each charge then you might consider the relays. In reality if you have lithium cells I wouldn't use a PakTrakr on them because of the imbalance they create in the pack.
1 - 2 of 2 Posts
