Im building this small tractor. Motor is 80 Amp cont 24 volt. I now have 3 batterypacks, each 24 volts, 100Amp hours, they are different age and make. To avoid over load on weak pack, I thought I would pull power from each pack seperately. So pack 1 is used until low volt limit is reached. Then pack 2 and then pack 3. Switching by hand, when Volt meter shows 12.0 under load. Does this make sense? Each battery pack says it will deliver max 100 Amps. Thanks, John in Denmark
