I have a Synkromotive controller. I'm having an issue with the limiter for the tachometer. The RPM matches what the car's tachometer reads, but the limiter seems to trigger at about half of the value I have set. Right now it's set at 6000 rpms just so I can get 3200 or so for my top end. I hooked up an o'scope, and it was a little noisy. It seems like if that was the problem, though, then the actual reading would track the noise as well. Any ideas?
Sent from my SM-G920V using Tapatalk
