1 - 4 of 4 Posts
Most important parameter is Peukert exponent of 1.
The other parameters are pretty self explanatory, with one exception. The charge efficiency factor f5.6 is defaulted to "auto"- on mine, I set it to 100%. It is much more accurate that way. I find that mine is inaccurately recording the small trickle of current out of my main pack into my DC/DC that maintains my flooded lead acid auxilliary battery which runs my BMS when the car is sitting around. That fools the algorithm into thinking there's a charge efficiency different than what it really is, which is actually near 100%.
I don't bother with the auto-synch paramaters- I synchronize manually when a charge has just been completed.
1 - 4 of 4 Posts
