Selling a pcb/enclosure that takes a Teensy3.2. Board has 3 analog inputs and 3 mosfet switched outputs for controlling relays, etc. Comes with mating Molex connector, external usb connection and spare terminals.
Some use cases for analog ins would be throttle and brake pressure in order to do some preliminary processing in the Teensy and controlling those inputs to an inverter over CAN or use the outputs for driving analog gauges, water pump or fan relays, etc.
Teensy3.2 will also run SIMPBMS firmware as well.
$220 shipped
Can also supply as....
With Teensy 3.2 for $250 shipped.
Just the PCB with smt components populated, you supply Cinch enclosure and Teensy $100shipped (3 available in this configuration)
Sent from my iPhone using Tapatalk
$220 shipped
