1 - 5 of 5 Posts
What are you using to test your builds before assembling batteries?
I have limited space and funds so I'm putting off purchasing my battery pack until I get everything running. I have the Siemens AC induction motor/DMOC inverter controller combo, so require 250-400 volts DC for no load run-ups. Suggestions?
A variac that I tap to get as high a voltage out of as possible. Then you get your 1.4x boost from converting to DC.
Otherwise, I'd rewind a microwave oven transformer, that's probably the cheapest (free) option.
I guess current isn't an issue, then?
Well by "test" I presume you mean to test the electronics and perhaps the driveline, unloaded.
Not "test" as in, replicate the full current of the motor under load.
A variac will have a current rating. Smaller ones around 3a, larger ones 15a.
That gives you ~1800 watts from a normal household outlet for a bigger variac. That's probably enough to get it spinning, though it might require some temporary overloading at first. Variacs can handle that, as there's no electronics, it's just wire that's going to heat up. Don't do it often, but, it'll handle motors.
1 - 5 of 5 Posts
