1 - 2 of 2 Posts
It looks as if the Tesla model 3 rear motor will be a good fit for my application, but I am having difficulty finding exact dimensions
Does anyone have a motor they could measure and post the results?
Particularly interested in the distance between mount point centres and offset relative to the output shaft centre line
Discussion Starter · #2 ·
In case anyone finds it useful, nearest approximation I can get is using the configurator and the known rear track of a model 3 which is 62"
Using that scale, the distance between centres of the motor/inverter mountings is about 24.5", and the distance between the line through those mountings and the output shaft mount is ~14.5"
Feel free to correct if you have an actual unit!
1 - 2 of 2 Posts
