I am converting a 25 hp gas outboard motor to an 18kW electric PMAC motor for use in a hydrofoil assisted power catamaran. Converting an outboard to electric is something I've done a couple of times but this time I'd like to make my battery safer. My last electric boat is a little lacking in the safety department - Electric Foiling Catamaran from Recycled Parts.
This time I'd like to use 6 Tesla Gen2 XS modules. 3 modules will go in a box on each side of the boat. This is a 72v system so I'm thinking that the 3 modules in each box will be wired in series then the two boxes combined parallel.
What I'm hoping you very knowledgable people here can help me with is battery box design. My thought is to make a watertight (within the limits of the IP67 rated vents) steel box out of .050" - .080" thick sheet that fits fairly close to the size of the 3 modules. That steel box would have a battery box vent Vent valve for battery box - EVcreate
and a layer of furnace insulation on the outside. The steel boxes would be mounted inside of composite boxes that are used as seats and will also hold BMS, contactors, fuses, emergency shutoffs, etc.
This is a carbon/honeycomb boat and I'm fighting to keep the weight down so that I can drag around those heavy batteries without too much performance loss. It kills me to think of 100 lbs of steel boxes onboard but I'm not seeing a way to mitigate the fire risk without something like that. It sounds like aluminum's melting temperature is not up to the job.
Any thoughts? Am I overthinking this? I'm not pulling a lot of current, maybe 200 amps continuous. I think that's like .5C. Charging C rate would be substantially lower.
