Big day today. First wheel spin and run of the Tesla drive unit in the E31.
https://youtu.be/YUNk_PIdp8E
Congratulations, that is amazing! Love how quiet and smooth the drivetrain isBig day today. First wheel spin and run of the Tesla drive unit in the E31.
It is tidy, but the fit is only easy into rear-wheel drive vehicle with a trailing or semi-trailing arm rear suspension; the motor will interfere with the control arms or subframe of almost any multi-link or double-A-arm suspension not designed specifically to accommodate this drive unit. That design is obsolete now, but was standard practice for rear-engined vehicles (especially VW) and for a few decades of rear-drive front-engine cars with IRS... such as BMW, Mercedes, Datsun, Toyota, etc.That is so neat!
You could fit that to almost anything
Disagree completelyIt is tidy, but the fit is only easy into rear-wheel drive vehicle with a trailing or semi-trailing arm rear suspension; the motor will interfere with the control arms or subframe of almost any multi-link or double-A-arm suspension not designed specifically to accommodate this drive unit. That design is obsolete now, but was standard practice for rear-engined vehicles (especially VW) and for a few decades of rear-drive front-engine cars with IRS... such as BMW, Mercedes, Datsun, Toyota, etc.
If all you need to cut out is some crossmember that's not bad (although more work than with semi-trailing arm setups like this older BMW), but when the cutting disks take off control arm mounts it's not quite a "doddle"....
The advantage of that design is that you only need mounting points for the cross beam
It would be a doddle fitting that in the back of almost any front or rear wheel drive car
All you need is lots of cutting discs and the correct attitude
On the prototype VW Bus we cut one chassis cross member. However, we have realised that this is unnecessary and the next version will bolt on without any cuts.I don't think Kevin or others have found putting a Tesla drive unit in to VW van to be trivial, either; they're getting there, but had to cut vehicle structure to get it in...
That will be interesting!I'm putting a tesla drive unit in the back of a 1969 Jaguar XJ6. Im aware it will be complicated to fit and i need to add an upper control arm.
Do you know the width of the motor? Did you measure prior to installation?the motor will interfere with the control arms or subframe of almost any multi-link or double-A-arm suspension not designed specifically to accommodate this drive unit.
The more recent rear-engine Porsches (since the 993, the first without semi-trailing arms) might be an unusually easy fit for a Tesla drive unit, among cars with multi-link rear suspensions, because they are already designed to clear a wide engine immediately behind the final drive housing.I am wondering if it might fit in the back of a Porsche 996 widebody. There is a lot of room between the subframes, and LOTS of room behind them. Even if it had to be mounted a little way back, and a little more angle on the CV joints.
