No problem; your English is far better than my Swedish!I will try to improve my english![]()
I assumed that equipment would be in front in a Tesla - is it normally in the back, or is this a Tesla front motor?... also making a box over the motor for all electrical equipment. Using Tesla original cables, best position to make it fit was on top of motor.
Now it will be " två flugor i en smäll " translate that in google![]()
ThanksHello, I agree brian_, a box on top of the motor is not the best. But if I want to use original cables it had to be like that. And I had to make some sort of hood over motor anyway and also some box for electronics. Now it will be " två flugor i en smäll " translate that in google
It´s a rear drive unit from Tesla, normally high junction box and charger lies under rear seat in a Tesla.
Are you aware that you're missing the box that switches between 1 and 3 phase AC? It's fitted to the HVJB on the opposite side to the Charger. You can see it in the attached photo.Also prepared some cable mangement and mounting plate for HJVB.
I can find no reference to the 'box' in the Tesla service manuals and parts lists... I'll publish the part number when it arrives. I also need to understand how Tesla supported both 1 phase and 3 phase charging on the dual charger setup (afaik the 'box' only supports a single chargerIf I want to look for one box, what is i called ??
