About to start converting my 350z track car to tesla power this will be used as a test bed along side Kevin's and Damian's projects. I will be using the large rear tesla drive unit which i brought from a 2015 tesla model s 75d with only 1600 miles on the clock. It will be fitted out with Damian's open source control board. The plan s to use as many tesla components as possible.
Everything will be set up on a bench first then i will strip all the redundant 350z parts and build a custom tubular rear subframe and battery box from the front.
