Just a note, I purged some personal squabbles from this thread. If you feel it was unfair, and these were beneficial to the community, PM me and we'll discuss it.
This does not make sense. If you claim to have "real data", then you must think you have "better information". This spreadsheet is what information, and yes assuming some errors, is out right now by one author. By all means, show us more correct and up to date information, if you have it. Or, better yet, do the research and make up a better spreadsheet.I did not claim that I had better information; I only distinguished between these numbers and real data.
Again (and again, and again...) I did not claim to have real data or better information. But thanks for confirming that this spreadsheet contains at least values which are not real data or confirmed information.This does not make sense. If you claim to have "real data", then you must think you have "better information". This spreadsheet is what information, and yes assuming some errors, is out right now by one author.
I said that the truck was driving at 55 mph or less for the journey.A rational discussion of most of the interesting issues regarding the Tesla Semi, as an update of an earlier discussion:
YouTube by Jason of Engineering Explained: Does The Tesla Semi Make Any Sense? Part 2!
Sources and basis for values and calculations are provided. While there are minor issues, I generally agree with this analysis.
Mirrors need to be large for safety; reducing their size is a bad idea, and replacing them with cameras is presumably still not legal in the USA. Other than some specialty vocational models, highway tractors have nose shapes from this century (usually revised within the past decade), not the 1970s.Cool video about the Tesla semi. Some key takeaways from the video:
-aero is not just good but really good
It doesn't break the laws of physics it just doesn't have big elephant ear mirrors and a 1970s blunt nose.
The number being used for efficiency is not Tesla's official 2.0 kWh/mile, but cherry-picked by the Youtube fanboy from an interview where Musk is bullshitting he sees 1.7 and sees a path to 1.6.I meant to add this graphic to my last post showing all the EV trucks and their efficiency. You can see how much better the Tesla is.
Thinking about thatMirrors need to be large for safety; reducing their size is a bad idea, and replacing them with cameras is presumably still not legal in the USA.
Cameras will be legal eventually. May take a few dead (natural causes) senators first though.We also don't allow laser headlights here.
You especially notice these idiots right after spending a couple of weeks driving in places like Germany. Drivers in the US are very undisciplined, don't know the rules of the road, they flip you off when they take your right of way, they undertake when passing, hog the fast (passing lane), and will speed up to block a signaled lane change.
And you want to make cameras legal?
Cameras are SAFER than mirrors - especially on a Tesla with the computer putting a flashing icon around anything that it thinks you should look atWe also don't allow laser headlights here.
Lose the 12v and your diesel stops workingLoss of 12V is probably the reason.
That's a lot of words to say that the Tesla is very aerodynamic and the other semis are notMirrors need to be large for safety; reducing their size is a bad idea, and replacing them with cameras is presumably still not legal in the USA. Other than some specialty vocational models, highway tractors have nose shapes from this century (usually revised within the past decade), not the 1970s.
But aerodynamics certainly are important, and the Tesla Semi probably has lower drag than trucks using the same cab as their diesel counterparts. Part of that is managing airflow under the truck, which means a smooth bottom (almost automatic for much of the length within the wheelbase due to the battery cases) and minimizing the amount of air which gets under there. All of the experimental trucks built in the past couple of decades (with diesel engines) have substantial aerodynamic improvements, but one reason that their designs don't go into production intact is that the low nose and shallow approach angle needed to effectively keep air out from under the truck are not practical in operation.
PepsiCo's use of their Tesla Semi fleet in actual commercial operation has led to some interesting opportunities for information, including how these trucks are towed when they break down; it's different from the manufacturer carrying them around on lowboy trailers. I'm not concerned about the breakdowns - stuff happens, especially in early production vehicles - but this recent photo shows a challenge for the tow operator:
(from a Facebook post)
It appears that the orange tow loop was used with the tow truck's wheel lift to pull the Semi onto the ramps, to get it high enough to fit the wheel lift under the Semi. I have to do something similar with my Triumph Spitfire, driving it onto shallow ramps (regular garage ramps are too steep) to get an ordinary floor jack under it... but that's a tiny sports car, not a truck.
It looks like the Semi would benefit from air suspension in the front (most heavy trucks have air suspension in the rear, but basic old leaf springs and beam axle in the front), so the nose can be lifted as required.
By the way, the legally required markings on the door confirm the 82,000 pound GCWR. Here trucks are also required to display their tare weight, which would be great information to have about the Semi, but Colorado apparently doesn't require that.
Yes, that's one solution, and it is available: small mirrors with cameras mounted in them, and interior monitors for the cameras. See the Digital Mirrors section of Kenworth's T680 web page, for instance. Gee, imagine one of those diesel-building dinosaurs offering advanced systems...Thinking about that
If you legally NEED the mirrors - but have the cameras anyway - why would you fit large mirrors?
Would you be able to fit dinky little aerodynamic mirrors to comply with the law while using the camera system
For a truck one of the main uses is when reversing - and todays camera systems are massively superior
