Hi, does anyone know where I can find information and dimensions for a Tesla Small Drive Unit?
I've made lots of postings about the Tesla Small (rear) drive unit.Hi, does anyone know where I can find information and dimensions for a Tesla Small Drive Unit?
You can find some overall dimension for the small rear drive unit in my build thread (here).Hi, does anyone know where I can find information and dimensions for a Tesla Small Drive Unit?
Thank you. I'd come across this page before, but I can't find any information regarding dimensions. There's not a lot of information about the Tesla SDU on the internet at all!From another thread...
https://hsrmotors.com/hsr/products/front_small_du
Thank you. I've taken a look and seem to have come across some dimensions you'd posted a while back. Am I right in thinking there are TWO Tesla SDUs? Front and rear? I thought there was just the SDU and LDU?I've made lots of postings about the Tesla Small (rear) drive unit.
www.teslorean.com
TesLorean on DCMTalk.org
TesLorean on DIYElectricCar
If I haven't posted them somewhere else, I can also provide rough (not CAD) dimensions.
Jeff
Great! Thank you, Kevin. All very useful.
Correct, their are two 'small' drive units, front and rear. The front DU stands more upright and has slightly different gearing from the rear.Am I right in thinking there are TWO Tesla SDUs? Front and rear? I thought there was just the SDU and LDU?
No problem. If you're in the UK (please add your location to your profile) then Chris Hazell (here) has all Tesla drive unit variants for sale and may provide access to one for measurement if requiredGreat! Thank you, Kevin. All very useful.
Ha! How weird! I'm also based in Bristol, England! Thank you, Kevin!No problem. If you're in the UK (please add your location to your profile) then Chris Hazell (here) has all Tesla drive unit variants for sale and may provide access to one for measurement if required![]()
It seems reasonable that these drive units must run most of the time in the normal rotational direction, but judging from the drawing and photographs that I have seen, in all cases that means that the motor is behind the axle line. The following image, one a series originally produced by Tesla Motors, shows all of the drive unit variations:Important consideration from a conversion point of view for the front and rear small drive units, is that for their transmission fluid pumps to work, they must be oriented as they are found in the model S. That is...
front drive unit : motor/inverter leading - differential gear following
rear drive unit : differential gear leading - motor/inverter following
To explain that further, I think that the front unit places the motor higher to clear the front of the extended case of the 85 and 100 kWh batteries - the overlap of motor and battery case is visible in the illustrations above.Correct, their are two 'small' drive units, front and rear. The front DU stands more upright and has slightly different gearing from the rear.
While the HSR catalog says the gearing is the same for both front and (small) rear, I think Kevin is correct, as I have read multiple references to that gearing difference. I believe that the front unit is geared taller (less reduction), so that it is optimized for higher road speed: ~9.73:1 in the rear and ~9.34:1 in the front. Since most discussions of the gearing difference are in Performance models (which have a large rear motor), it is also possible that small rear drive units have the taller (~9.34:1) gearing as HSR says.
I will find out and post the gearing for the small front and rear drive unit in the next week or so as currently have both opened up to design a limited slip differential
Sent from my iPhone using Tapatalk
Fascinating... so the same as one another but different from the 'large' rear iircSo both front and rear small drive units are geared the same.
Thanks Chris!So both front and rear small drive units are geared the same. Info below.
Primary drop = 78/31 = 2.516:1
Final drive = 79/21 = 3.762:1
Overall ratio = 9.465:1
It makes sense. Both small units were designed for use in the AWD ("Dual Motor") models only. With two motors (even small ones), the gearing could be taller than with a single (albeit larger) rear motor. The resulting mismatch in front to rear gearing when a (small) front motor and large rear motor are combined (a "Performance Dual Motor" variant) appears to be accidental, and it is certainly harmless.Fascinating... so the same as one another but different from the 'large' rear iirc![]()
Have you confirmed that the differentials in the small drive units are different than those in the large drive units? If not, you can use the Quaife unit from EVTV designed for the large drive unit.I will find out and post the gearing for the small front and rear drive unit in the next week or so as currently have both opened up to design a limited slip differential
They are differentHave you confirmed that the differentials in the small drive units are different than those in the large drive units?
