Looking for the cheapest solition that I can plug into a single phase source (120V or 240V) that will spin a 3 phase motor (various models) up, at variable speeds.
I don't want the full power from a proper-sized inverter, but to bench test motors, adapters, pumps, etc. for eventual EV project integration.
I also don't want to spend time on it - ideally plug n play and ideally is self sensing vs needing resolver hookup.
A kilowatt or two in size is fine as there's not much loading. Variable voltage max would be good. Couple hundred volts would be nice.
Ideas?
Ideas?
