Fiat 124 Spider (Kostov 11HV), BMW 330Ci (NetGain 11HV), Piper Aircraft Malibu (YASA)
Hi All,
wanted to get your opinions on the test I am about to do on a hybrid pack I am trying to build.
Basic idea: build a hybrid pack out of low-discharge-current LiFePo4 (sized for range) and high-current LiPo (sized for max current draw).
Objective: feed a 1000A controller such as Soliton1 for 15+ seconds of full power up to max RPM of Warp9/11 motor (i.e. ~170-180V on the motor). With a pack voltage of 250-300V this probably means ~10s of 750A draw on batteries (assuming other 5s spend in sub-top-RPMs where controller duty cycle is low enough not to worry about max battery current).
Requirements: Pack capacity: ~20kWh. Pack weight below 500lb (about as much as I can fit into my small donor car). And I do not want to kill the pack with excessive current draw.
The weight limit pretty much means that I can NOT just size my pack to satisfy 3C max that TS wants for anything beyond 3s duration (CroDriver posted elsewhere that TS can go for a few seconds of 10-20C but only 1-3 sec at a time per manufacturer). 3C in my application would mean a 300V pack of 200Ah cells - ~1,000lbs... Not going to work.
I believe this is the kind of dilemma faced by a lot of the builders here - how to get good acceleration up to the limits of the controller without having to have a truck to carry the batteries.
Now, I know about A123 and Headways but I am not super-comfortable and happy stringing 600+ little cylinders / pouches together. Also, this solution would likely be at least 2x more expensive.
Hence the attempt to marry the ease of install / safety of large lifepo4 prismatics and crazy power density of lipo (I do know the volatility potential of LiPo and do plan to take measures to monitor their state and contain any potential "events").
Setup: 2 battery strings in parallel:
1. "Slow" prismatics pack of X 3.2V nominal 100Ah CALB or TS cells rated for 3C continuous and 10C for 3s (per CroDriver). This would give up to 300A for 15+ seconds without impact on cell life. $0.35/Wh, $140/kW continuous
2. "Fast" Lipo pack of Y 3.7V nominal 10Ah RC LiPo cells rated for 45C continuous / 90C burst discharge (similar to http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14617). This would give 450A+ for 15+ seconds without impact on cell life. ~$0.8/Wh, ~$90/kW continuous.
The resulting 110Ah pack would have ~$0.4/Wh so just 14% more expensive than pure LiFePo4 pack but would give 150% more sustained power (if all the stars align, that is
The X and Y (numbers of cells in the strings) will be selected to:
1. Have the "fast" pack provide majority of the current in high-current demand events
2. Have the "slow" pack do same in the low-current demand events
3. Have the "slow" pack to re-charge "fast" pack during the periods of the low-current draw (optional - if you size the 'fast' pack right, you would be running out of range before draining the fast pack - see below)
Obviously, all this depends on the 'fast' pack being 'stiffer' than the 'slow' pack on discharge - i.e. lower voltage sag at the same current. Then, since both packs are connected in parallel, there will be a cross-over in current-supplied vs. voltage curves which will make this idea possible.
To see if this concept even holds water, I am planning to do a number of tests. Some of these tests will be useful for people who just use large prismatics. I would love to get some feedback on the concept and the test design from the experts on this forum.
Test setup:
Equipment:
1. 20 LiPo cells for 74V nominal
2. 23-27 LiFePo4 cells for 74-86V nominal
3. Soliton1
4. Resistive load capable of dissipating up to 60-70kW. Designed to draw 1000A at ~50-55V (so that the battery draw would be at ~750A - max 15+ sec combined rating for the two strings). This would mean 50mOhms load. Will be a large DIY heating element submersed in a large reservoir of running water.
5. Hall effect DC amp meters on each string and a resistive load
Procedures:
I. large prismatic string alone
1. IR / voltage sag test. Apply 1/2/3/4/5/6C loads at 100/80/60/40/20%SOC and record voltage sag from nominal. Derive IR from the data at various points during the cycle
2. TBD (any ideas for what would be useful?)
II. LiPo string alone.
1. IR / voltage sag test. Apply 10/25/50/75/90C loads at 100/80/60/40/20%SOC and record voltage sag from nominal. Derive IR from the data at various points during the cycle
III. Hybrid pack (2 strings in parallel)
1. Based on the IR data derived in I & II, and charge / discharge profiles, determine X & Y (# of cells in each string).
2. Build the strings, connect in parallel, connect resulting pack to a controller
3. Apply resistive loads of up to 1000A with 100A increment. Monitor currents at each string.
4. Understand the current distribution under different loads. Tune for desired behavior: I_slow>>I_fast at I_total<<300A; I_fast>I_slow at I_total>500A. Tuning done by adding / subtracting 'slow' cells.
5. Repeat #3 for different SOC of 'slow' cells. Confirm cell ratios still work.
What do you guys think? Has anybody tried hybrid packs like this before? Is this a crazy idea? What are the 'gotchas' I haven't thought about? (for example, longevity of LiPo pack can be a concern with such kind of usage. However, some prelim calcs show it's probably going to be fine. A typical 12-15s acceleration event (1/4 mile pull) would consume ~10-15% of the LiPo cell capacity. A typical 5-7s event (0 to 60/freeway) would consume ~5-7%. In normal 'spirited' street (not race) driving one could expect to have <10 events of the latter type per EV range hence we could assume 1 'fast' pack 70% DoD cycle per 1 'slow' pack cycle which is not too bad).
Please chime in. I will be doing these tests anyway within the next few weeks (as soon as I get my components) but want to make sure that I get all your input into the design, etc.
Thanks!
Test setup:
Equipment:
3. Soliton1
Procedures:
Thanks!
