Since I plan to add a few more cells to my LiFePO4 pack, I am making some changes to my box and this provides a perfect opportunity to verify my cells individually.
I'd like to test my TS LFP160 cells after having done 7000 miles and thought I'd try find a way to discharge some or all of the cells to see how long it takes to get down to 2.5V or close to it. I basically want to determine if I have any bad cells or cells with drastically reduced capacity. I don't have any speciaized equipment and would be trying this in a more or less household environment. I'm thinking of doing a slow discharge of 0.3C or 50 amps to dissipate approx. 153 watts of energy. Based on my calculation, I would need a 0.06 ohm resistor and appropriate contactor. This is where I get stuck a bit.
Which resistor would I be best advised to use?
I realize that there are many options like graphite resistors, sliding contact resistors, golf cart starting resistors, older forklift resistor based motor controllers, old electric furnace elements....
Can anyone offer any good advice or point me to a source for a good resistor/contactor to use for this type o battery test?
