Got it! Thanks again.![]()
Spring pin - Wikipedia
en.wikipedia.org
en.wikipedia.org
Looking at this design again, I think it will only work if the drive shaft sleeve is a relatively tight sliding fit on the motor output shaft. The single support bearing, if it is a typical single row unit, will have quite a bit of twisting play between the inner race, the balls, and the outer race. This, combined with a loose fit of the sleeve on the motor shaft, could make for excess side play(wobble) of the drive shaft- about where your hand is grabbing the yoke in the picture. You could check for the side play, after the parts are assembled, by moving the yoke side to side with your hand. Or, set up a dial indicator to measure it.
Too expensive and not needed at this level.I figured you Moab people wouldn't settle for anything short of beadlock rims?
I think that's true for a Leaf, but Isak at Resolve-EV said it's not required for the custom controller. Everything else functions correctly. If I change the model year around in Leafspy it gives me different data or nothing at all. The screenshot shown was using it set to 2013.I thought if you used a different LEAF battery pack, it has to be paired to the new motor/inv or retain the original battery's control module? Sorry if you've already mentioned that in the thread and I didn't see it.
I added a simple switch inline with the brake 12v signal wire so that I can simply disconnect the brake input from the Resolve-EV controller. It is not ideal but it works!I haven't been following too closely. Have you resolved the issue with holding the vehicle's position with the throttle on an incline? Also, what's the latest with the drive line vibration?
Thanks for the clarification. I am using the Resolve controller as well, and wasn't aware of this.I think that's true for a Leaf, but Isak at Resolve-EV said it's not required for the custom controller.
You need to have a small amount of angle: Driveshaft Angles: Why They Matter And How Keep Them In CheckNow the driveshaft is held just about perfectly straight.
I actually read that exact article when I was contemplating the design. I tried to run it at a slight angle but the vibration was much worse. The guy who built the driveshaft told me to just run it straight also. It's good enough to get me to Moab and shake down the truck, as soon as I get back I'm going to start redesigning the drivetrain I've already decided.You need to have a small amount of angle: Driveshaft Angles: Why They Matter And How Keep Them In Check
Haters gunna hate. You should see my wife's Tik Tok comment section on her EV posts. Holy moly...Everyone loved it except one guy who called it an abomination lol
Your drive line is so short, it's going to be difficult to measure the angle accurately. You may already have the minimum angle. One option for the redesign is described in post 91. It has the direct mounting of the motor to the BB reduction unit, with an adapter plate.I actually read that exact article when I was contemplating the design. I tried to run it at a slight angle but the vibration was much worse. The guy who built the driveshaft told me to just run it straight also. It's good enough to get me to Moab and shake down the truck, as soon as I get back I'm going to start redesigning the drivetrain I've already decided.
Yeah that's the plan. I will need to "clearance" the trans tunnel in the truck so the motor can fit up close to the t-case but directly mounting it with CNCd adapter plate is the plan.Your drive line is so short, it's going to be difficult to measure the angle accurately. You may already have the minimum angle. One option for the redesign is described in post 91. It has the direct mounting of the motor to the BB reduction unit, with an adapter plate.
You can do well without CNC if you do it well, just saying. But a CNC bullet of aluminium always looks good when the truck is canted over on 3 wheels in the rough stuff and everyone's looking up its skirtYeah that's the plan. I will need to "clearance" the trans tunnel in the truck so the motor can fit up close to the t-case but directly mounting it with CNCd adapter plate is the plan.
Ignoring all of the (significant) details of before and after equipment differences, this illustrates the importance of the specific engine. The original engine in this vehicle is vastly heavier than the engine in a typical car, so the conversion doesn't see the weight gain that would typically be expected.Today I took the EV 80 back to the same scales that I weighed it on before I started. Everyone wants to know the weight, well here it is: 5180 lbs. Remember, when it was stock it weight 5080 lbs. So that means currently it is sitting 100 lbs heavier.
