No, but the rest of the car is designed around that tire size. I can gear the rear end anywhere between 3.08 and 4.56, though. Depending on the characteristics of the motor I select, I may add a reduction at the motor end, which would give me even more options to play with.
After more searches on the topic, I think people may have been confused in the first set of posts I was reading. They were saying the max continuous RPM of the motor is 3300 but that may not be accurate. The datasheet says its max continuous power is 38 kW at 3300rpm. It may be just fine sustaining a lower power output at higher rpm. Going to call Netgain tomorrow to see if I can confirm that. Looks like I'd be drawing about 16kW at 60 mph according to a rolling/wind resistance calculator I found.
