Our "Voltswagen" is complete, but upon delivering it to Vegvesenet (The Norwegian Public Roads Administration), they decided to be real strict (no home-made EV has ever been tried and tested for registration by them, so our vehicle will be leading the way and set an example for the future, and they need to tread carefully).
Here's the list they've given us:
We have a 3 batteries in the gas-tank and one at the very front of the vehicle where the spare tire sat.
Our batteries are of the GEL-type, so they won't spill, and I know for a fact that Volkswagen having a gas-tank right at the front of the vehicle wasn't exactly safe either. It's just that the placement of the gas-tank originally makes no difference to the officials... We're most likely going to fabricate some hardcore plastic and rubber-stuff to stick over the battery-terminals that won't break in case of a collision, but the officials are still going to demand what they call "a surge protector".
Also, how do we do in ways of heating the cabin? Living in Norway, it can get quite icy (not that the batteries have complained so far) and the windshield is going to need to be heated somehow. Are there 12V heaters that would do the trick here, and then make new channels leading up to the vents below the windshield? Would plastic/rubber tubes be sufficient, or do we need more heat-resistant stuff? Maybe they make 12V hairblowers? I don't know.
It's also sad that we have to remove the back-seat to get the weight-bureaucracy have it's way.. It looked really clean and stock with the rear-seats in.
Here are a few pictures of the car during the build and as it is today:
The struts that support the batteries in FWD-REV motion. I've done calculations of them not breaking under the load of a 60 km/h to 0 collision at 50 milliseconds. Should do the trick. There's an aluminum bar going across the width of all three, at the other side of the wall.
The batteries secured. After this picture was taken, we've pulled rubber-hosing (bicycle-tubes) over the aluminum profiles to make sure they don't short the battery-terminals. We're going to add floor-profiles in front of the batteries as well, to be on the safe side.
The front batteries and charger.
Plexiglass-cover added to prevent unnecessary shocking experiences.
Before we started
After
Youtube-film of the car running:
http://www.youtube.com/user/magnareikerol#p/a/u/1/qxsSzuZgOvA
Most of these things are fairly straight-forward to do, however the part about preventing shorts in case of collision, we have no idea how to do.Security and protection of batteries; §24
- The battery-installment at the rear needs to be more secluded from rest of the cabin
- More protection is needed directly over the battery terminals, both for front and rear battery-packs.
- More protection between the battery-terminals and the racks/negative of the car body.
- Some sort of device that will prevent the power to short upon collision
- Protection of the leads inside the cabin
- Protection of the lead directly under the back seat.
Power
- Minimum of 5.89kw/8hp per 1000 kg total-weight (The total-weight of the beetle is set at 1200kg, regardless of the car currently weighing 974kg.) The current motor (rated at 5.2 kw) is at 4.2kw per 1000kg total-weight.
- You need ECE 100-approval of the motor (from the manufacturer)
Ventilation
- §17: A closed cabin must be able to be heated and ventilated in a satisfactory manner.
Electromagnetic noise
- There mustn't be noise that can interfere with radio and/or television signals
Weight
- Front axle: 452 kg | Rear axle: 522 kg | Total 974 kg | Original weight: 810 kg
- Registered total-weight for this type of car is 1200 kg, leaving passengers/cargo to be 226 kg, meaing only 2 passengers excluding the driver. A heavier vehicle would only allow 1 passenger + driver. The number of seats in the vehicle MUST be the same as the maximum number of people allowed in it.
Conclusion
- As you see, there are a few changes that must be made. This conclusion made in dialogue with the conversion-branch in Oslo, and SFOOR, but you have the right to complain/demand a reevaluation. This must be done at the local traffic-station you first presented the vehicle at.
Before we started
After
