Well, I ended up buying both a Tesla gen 1 iBooster and Honda gen 2 iBooster. If anyone needs any measurements let me know.
The Honda unit came with the same large connector 192840576, but a different connector on the pedal travel sensor. Also the Honda does not have a wire on pin 17 (12v).
The reservoir fittings are compatible, with slightly different retaining styles, but can be swapped.
The master cylinders have different mounts, and the pushrod ends have different mounting pattern and pushrod lengths.
I was able to wire up the Honda gen 2 unit and get assist. I have the pedal travel sensor connector for that and the wire colors matched with the large connector too which was nice.
However I cannot get assist with the Tesla gen 1 unit (which is the one I want to use). When I apply 12v to pin 20 on the large connector I hear the unit activate and slightly push on the master side (you can both hear and feel it), but there is no assist when pushing on the pushrod. Any ideas on how to troubleshoot?
I have wired it like this (LC=Large Connector)
LC1 --- 12v
LC2 --- pedal travel sensor pin 1
LC8 --- pedal travel sensor pin 3
LC9 --- ground
LC17 --- 12v
LC20 --- 12v/IGN
LC22 --- pedal travel sensor pin 2
LC23 --- pedal travel sensor pin 4
tia,
charles
p.s. if anyone bought any bulk terminals and has some to spare i'm interested in buying some.
LC1 --- 12v
LC9 --- ground
LC17 --- 12v
LC20 --- 12v/IGN
tia,
charles
