1 - 9 of 9 Posts
Hiya,
I am at the testing stage of the controller and i have a small issue with the throttle potientomer. I have got a poteniometer from a golf cart that seems to work fine. When i check the output of the PWM it only works in a small range of the potienimeter . Do i need to change the resistor in the logic board to make the range better?
Cheers Barry :D
https://photos.app.goo.gl/bJpiGo6jdfPJGegT8
Without having to dig into any previous threads you wrote, maybe you can share "What controller" you're using?
This is a general forum for all controllers, not a specific one, so new threads likely need some reference point.
That's good info.
What is the resistance value of the potentiometer you're using?
Does it match the value required by Damian's controller?
i.e. is it a 10k throttle, but the controller expects 5k?
How many wires go into damian's controller?
Was it a cheap chinese potbox? I had one that was wired really weird and did not work.
Hiya,
It asks for a three wire pot. I have a 5 k one from a golf cart and i have a 100k from a mobility scooter. I will try and find out what size the controller is set up for .
Thanks Barry
1 - 9 of 9 Posts
