Hello!
We are working on an electric boat that is powered by 82 100 Ah Cells from Thunder Sky. We also use the BMS 100 from Thunder Sky and a charger.
So far we have connected all the cells with the BMS and they all are shown in the Display and balancing works.
But we always have the error "invalid node warning" and I don't know what to do to solve this problem.
I tried to remove all the Cells and to remove all the collecting modules, but its very strange that the the error does not go away.
I measured the cable, it ok, we have all cells in the list of the BMS on the display, the current sensor works, but we cannot charge and use the batteries because we have this strange error and the charger is switched off by the bms because of the error.
Has anybody also a BMS from TS in use and knows about that problem?
Thanks for your advice,
Best Regards from Austria,
Hermann
Hermann
