I would suggest as many as will fit up front, not to exceed the stock front axle weight by more than about 100 pounds (FWD cars don't need to get more nose heavy.) The rest should go to the rear while not allowing the rear axle weight to exceed the front axle weight (FWD car suspensions are not set up to be tail heavy.) Likely that was a long way of saying fill the front then put the rest in back.
You can re-compress the cells, TS even shows pictures of such clamps. I wouldn't get carried away, I've heard just applying gentle force will flatten them over time if you don't overcharge. Swelling suggests the internal resistance is higher than new, I don't know if flattening the cells back out will take it back down.
46 cells will make a nice 144 volt pack. I've been slipping Lithium into the EV buggy this week too.
