I purchase tires from: www.tirerack.com
I buy the smallest width tire possible, yet keeping the diameter the same for the speedometer accuracy. Then I pressure them with nitrogen to 44lbs.
You can use this tire calculator to see a virtual image of your existing tire, compared to the new you are looking at:
www.miata.net/garage/tirecalc.html
Hope this helps.....
