1 - 1 of 1 Posts
Banned
Model No.
Topwheel TP005
Net Weight
48 Kg
Dimension
87 * 45 * 60cm
Battery
36V 14AH Lead acid battery
Voltage
100V - 240V
Motor Power
2000 Watts (2*1000w/pc)
Power
Brushed DC motor
Tire
19 in Vacuum Smooth (Aluminum Rim)
Height of Handle
80 - 110cm Adjustable
Maximum Load
287 lbs / 130 kg
Maximum Speed 20 km/h
Maximum Mileage
35 km
Height of Footplate 10 in
Max Height of Above Ground
5 in
Minimum Turning Radius 0
Maximum Climb Capability
30 degree
Standard Pressure of Tire
250kpa
Battery Show
LCD Screen Percent display
Charging Time
4-6H
Package Size
90 * 52 * 63cm
Gross Weight
57KG
1 - 1 of 1 Posts
