Here is some more interesting info I found, it's for designing racecars but, most info should still pertain
Chassis explained
As you design a racing car, it is important that you know the requirements of your engineering work. The nature of the race car's normal operation and fatigue life depend on the structure and material composition of the car. Therefore, topics such as metallurgy and structural design are important for the designer to grasp. The whole concept of engineering considerations is that you keep in mind four aspects, where they are appropriate:
Any good chassis must do several things:
•Be structurally sound in every way over the expected life of the car and beyond. This means that nothing will ever break under normal conditions.
•Maintain the suspension mounting locations so that handling is safe and consistent under high cornering and bump loads. This means that there is no flexing of the body, or at least to reduce flexing on lowest possible value.
•Support the body panels and other components so that evevrything feels solid and has a reliable life span.
•Protect the driver from external intrusion.
Structural stiffness is the basis of what you feel at the seat of your back bottom. It defines how a car handles, body integrity, and the overall feel of the car. Chassis stiffness is what separates a great car to drive from what is merely OK.
Contrary to some explanations, there is no such thing as a chassis that doesn't flex, but some are much stiffer than others. Even highly sophisticated Formula 1 chassis (actually, Formula 1 has monocoque structure) flex, and sometime some limited and controlled flexing is built in the car.
The range of chassis stiffness has varied greatly over the years. Basic chassis designs each have their own strengths and weaknesses. Every chassis is a compromise between weight, component size, complexity, vehicle intent, and ultimately, the cost. And even within a basic design method, strength and stiffness can vary significantly, depending on the details.
There is no such thing as the ultimate method of construction for every car, because each car presents a different set of problems.
Some think an aluminium chassis is the path to the lightest design, but this is not necessarily true. Aluminium is more flexible than steel. In fact, the ratio of stiffness to weight is almost identical to steel, so an aluminium chassis must weigh the same as a steel one to achieve the same stiffness. Aluminium has an advantage only where there are very thin sections where buckling is possible - but that's not generally the case with tubing - only very thin sheet. And even then, aircraft use honeycombed aluminium to prevent buckling. In addition, an aircraft's limitation is not stiffness, but resistance to failure. Aluminium problems are overcomed something with Audi Aluminium Spaceframe (ASF), very expensive and for now made in limited models.
Ladder Chassis (Body on frame technology)
This is the earliest kind of chassis. From the earliest cars until the early 60s, nearly all cars in the world used it as standard. Even in today, most SUVs still employ it. Its construction, indicated by its name, looks like a ladder - two longitudinal rails interconnected by several lateral and cross braces. The longitude members are the main stress member. They deal with the load and also the longitudinal forces caused by acceleration and braking. The lateral and cross members provide resistance to lateral forces and further increase torsional rigidity. Since it is a (little bit more than) 2 dimensional structure, torsional rigidity is very much lower than other chassis, especially when dealing with vertical load or bumps.
This technology you can find today in some basic auto racing categories. Most known is kart. On picture below you can see chassis of an Superkart car without bodywork.
Backbone chassis
Backbone chassis is a type of a car construction chassis that is similar to the ladder design. Instead of a two-dimensional ladder type structure, it consists of a strong tubular backbone (usually but not always rectangular in cross section) that connects the front and rear suspension attachment areas. The tunnel or backbone becomes a primary load bearing member.
Backbone chassis is very simple: a strong tubular backbone connects the front and rear axle and provides nearly all the mechanical strength.
Inside backbone is space for the drive shaft in case of front-engine, rear-wheel drive layout like in the case of Lotus Elan. The whole drivetrain, engine and suspensions are connected to both ends of the backbone. A body is then placed on this structure.
It is almost a trademark design feature of Czechoslovak Tatra heavy trucks (cross-country, military etc.), but this type of chassis is also often found on small sports cars. It also does not provide protection against side collisions, and has to be combined with a body that would compensate for this shortcoming.
http://www.formula1-dictionary.net/chassis.html
On an electric car/kart the battery pack is, usually, the heaviest (single)component after the driver.
I am thinkin' about a backbone chassis design that incorporates the battery box as a structural member rather than something to be supported.
This way most of weight of the batteries could be centrally located & spread out along the length of the frame.
The driveline (the battery cables, speed controller & most of the wiring connections) could be mounted & ran thru the inside of the tunnel/tube & would be protected in the true spirit of a backbone chassis
Chassis explained
Backbone chassis
