This is a spin off thread from this thread.
http://www.diyelectriccar.com/forums/showthread.php/highlander-hybrid-and-prius-motors-86829.html
It seems that there are several of us exploring using salvaged Toyota internal permanent magnet motors and Power inverters in our EV conversions but the motors and power electronics only have value if we can get a working controller.
There is a lot of information out there. Hopefully this thread will help some of us towards getting a working controller.
The current discussion is in regards to hacking the built in resolver for the needed rotor position feedback but feel free to add any information that you have regarding the control of these types of motors.
General theory is ok but more specific examples or experiments is preferred.
Here is a quote from one of the later posts
Jeff
I will explore multiple methods. You got me thinking about what would be needed to drive the resolver directly and decode it right along with my motor current regulation attempts.
I don't know what you mean by "truly open" but I love to have somewhere that I can bounce my ideas. I am not sure what the outcome so I do not make claims or predictions of what fruits it will bare. My signature states that my project requires a custom ECU for the Prius Inverter so yes we may have a common goal. There are others trying to use these motors but are not as vocal. I am sure they will be lurking.
After I asked you about the resolver drive signals, I did some searching and came to this site
http://www.tamagawa-seiki.com/english/lvdt/post.html
I think Toyota uses one of these "Singlsyn" models. This gave me a rough idea of the input impedance, frequency, and transfer ratio.
Here is a sketch of my resolver excitation driver circuit. I am planning to drive the two opposing sine wave inputs (D_EXEC, D_nEXC) from the two DACs on my uP board. Resolution TBD.
My uP board is 3.3V so I centered my DAC sin outputs at 1.65V +/- 1V. The opamps shift, amplify (4x), and smooth. This results in a differential output of 16Vp-p. I am only using positive voltage supplies. See my simulation: (click on image to expand)
I am going to measure the SIN and COS returns using a AD7609 which I am also using to measure the motor phase currents. It can simultaneously sample and converter 8 differential measurements. Once I get this hardware spun up I can start hacking on some code.
Is that open source enough for you? I would post this in the "Toyota IPM Motor Control Design Details Thread" if you had one
Jeff
Jeff
