Long time listener, first time caller.
Thought about tacking this onto a recent thread about a CJ7 conversion but decided it was different enough to start fresh.
Been thinking about an EV conversion for a LONG time and one of the ideas that keeps bubbling up to the surface is an old CJ5. One of the reasons is because it may be one of the easiest ways to achieve the mythical direct drive conversion.
No need to rehash the +/- of dumping the tans and transfer case, it's been covered before. A CJ/Wrangler style could be well suited to this for several reasons:
1) Light weight (even lighter with all the fiberglass tubs available)
2) Lots of very high ratio axle gears available (or axle swaps)
3) Can fit 2 electric motors side-by-side (I think) where the transfer case sits (one facing rear, one facing forward. Front diff is already offset)
4) Easy to get custom drive shafts
So I put together a spreadsheet to check some numbers and here are the highlights:
For "stock" Jeep numbers I just used very generic stuff as there are so many combinations out there,
28" tires
3.31 axle ratio
3.52 1st gear
2.27 2nd gear
4.0 I6 motor
220 ft lb max torque at 2800 rpm
With 31" tires and a 4.88 axle ratio the EV motor would be spinning 3700 rpm at 70 mph (pretty low rpm
I looked at roughly duplicating stock acceleration by matching stock wheel force. (I know, I know, a Cj5 with a glass tub, modern 4.0 and low gears would go like hell. It's a starting point)
To yield the same tire force numbers you would need each EV motor to have 290 ft lbs (1st gear equiv) or 190 ft lbs (2nd gear equiv).
So, most likely a pair of motors with a torque output between the 2 would result in pretty good acceleration. Maybe 200-230 ft lbs. High, but not outrageous. For the highway it probably only takes about 50-60 hp to keep it moving at 65 so that shouldn't be to too hard to get with 2 motors except for the problem of low rpm.
I looked at a couple of motor curves and estimated some efficiency numbers. With a big grain of salt, it looks like it would be getting around 1 mile/kWhr on the highway which seems really poor. I have a Soul EV right now and get 2.5-3 times that on the highway.
I'm trying to wrap my head around the trade-offs. 2 motors doubles the torque to compensate for the torque lost to gearing. But you double the power, which really only matters for top speed. Top speed would be irrelevant as long as you can reach 70mph. Efficiency seems worse running lower rpm. Weight, losses, reliability and complexity are better.
A crawler box could be cheaper than a second motor. But some are very noisy. Maybe high torque/low power motors are an advantage in some way?
Any thoughts on motor selection? Things I'm missing? Anybody tried it?
28" tires
3.31 axle ratio
3.52 1st gear
2.27 2nd gear
4.0 I6 motor
