Assuming that you mean from the motor to the propshaft - that is the way my "Device" works
It means that you can put the motor where the gearbox would live
https://www.diyelectriccar.com/foru...dubious-device-44370p15.html?highlight=duncan
Mine was dead easy the Hitachi motor had a brake on one end - I snaffled the female spline drive and made a simple disc adapter to the prop shaft
