21 - 40 of 63 Posts
· Administrator
Hi
I would throw that coupling away - the very way it works guarantees that it will not be concentric
Can you shift the motor back the ten inches? - Shorter propshafts are better - if you have to do some metalwork expanding the transmission tunnel that is better than messing with the propshaft
You need a proper coupling the type that uses a conical thing to clamp onto your motor driveshaft
· Administrator
I guess I could, would I still need a new driveshaft? I could even move the motor mid ship and hook into the diff. But, in any of these configurations I would need a slip drive shaft of some sort, correct?
Yes - you still need a slip/plunge joint -
change the order of events -
if you can move the motor then take your propshaft to your handy local scrapyard or other supplier and have a look at what he has
Then go back to the motor position - rinse and repeat until you have got it sorted
A new propshaft is not that expensive - could be best to bite the bullet and get a new one
A couple of other ideas (recognizing this is a '54 Ford):
1) Mount the motor on the rear carrier, no driveshaft or slip joint, still need a coupler if you don't use a chain or belt drive, or
2) Put an IRS in the back (many hotrodders, nowadays, known as "restomodders", do anyway, which again eliminates the slip joint, needs a coupler and an arbitrarily long driveshaft. Unlike the old days where Corvette and Jag were the only readily available choices, there are a few more out there for IRS these days.
One other issue you need to think about with your industrial motor (seems to be a secret of what it is with the way you took the pics, so I have to guess that's what it might be given the keyed shaft) is cooling.
Most stationary motors have an integral fan on the rotor, which is completely useless at low RPM, and that's where most people dump the highest current into a traction motor. You can get some motors that have a separately motored fan from things like machine tools (not cheap).
Maybe you have that taken care of, but getting gobs of air down a trans tunnel that's plugged by a motor is a tough nut to crack as well. Especially fun when you have a block of batteries blocking airflow to the tunnel.
You also are starting out with a heavy car. Coupling it to the rear end by whatever means only gives you a 3:1 to 5:1 torque increase. If you're using a 3600 RPM motor, you don't have much choice but to couple to the rear end if you want to have a chance at hitting highway speeds, If it fits in a tunnel, with direct drive acceleration could be sucky, though.
I'm sure you've done the math on wheel speed. Less likely you did the math for acceleration. Putting the motor anywhere, including the engine bay, needs thinking about cooling and not merely about how to attach the rotor to a prop shaft.
As I said, maybe you've thought about all this, but if you (or future project folks) haven't, you may be in for a nasty & expensive surprise.
Discussion Starter · #25 ·
Interesting info. I am still in the early stages of this project so am open to all possibilities. The car had an automatic transmission so i'm in search of a manual swap. But they are pricey.
It is a heavier car but the car is being placed on an extreme diet and hope to get it down to 2200-2500 pounds.
Now mounting it in the rear is an interesting idea. What is it you mean to mount it to the rear carrier?
I can someway get air to the motor, the car had fresh air inlets at front grill that I can use ducting to get air anywhere, but that would only help at higher speeds.
So, I am looking for ideas, any info at all would help me greatly
A differential carrier mounted traction motor is really crappy for unsprung weight, but if you're driving a land yacht or truck it doesn't matter a whole lot and it does completely free up tunnels and the volume between the frame rails.
It's used a lot on golf carts and on some medium-heavy electric trucks like the Wrightspeed.
Here's an engineered solution to get you brainstorming: https://www.trucknews.com/products/workhorse-using-dana-axle/
Lots of possibilities. All you need is time & money.
On my project (59 Cadillac) I used a TorqueBox 2:1 gear reduction unit. The optimal efficiency of the tandem motors (Siemens Azure) is around 6000 rpm, and with the gear-ratio of the differential, the wheel-size etc that'd be just north of 150 mph. With the TorqueBox installed it should be around 75-78 mph, pretty much the cruising speed on my commute.
The output shaft of the TorqueBox has a yoke that fits the U-joints/bearings of the original drive shaft, and it has the splined input & adapter plate to mate to the motors. Not the cheapest way to go, but an elegant solution for sure.
John Wayland did this decades ago using two motors. You should upgrade as your car weighs twice what White Zombie does. http://electricandhybridcars.com/index.php/pages/worldsfastestcar.html This is an old link. You may google to find something newer but since this page was made the car was reinforced due to all the wheelies. New lithium pack. Involved in a crash on a TV show.
For a 54 Ford (say a Customliner sedan) you do need 2x something.
In this case, I think you can make it work with 1 motor and a 2x gear reduction. The gear reduction will halve your rpm (so now the 6000 rpm from the motor fit the 3000-rpm drive train design) and it will double your torque. That should get the total weight off the line with normal-people performance.
If you want white-zombie-speeds etc then yes, the whole car needs to be reinforced etc.
I'm doing a 1959 Cadillac sedan, and it's with 2 motors and a 2x reduction. A Karman Ghia is 1800 lbs and uses 1 motor & no gear because the drive train needs 4000-6000 rpm, the Ford Customliner at 3500 lbs would use 1 motor and a 2x reduction, and the Cadillac is 5600 lbs with 2 motors and a 2x reduction.
There's a weird logic in those numbers but I think it all works out....
· Administrator
You only want the reduction gear if you are using a wimpy AC motor
A DC motor is a LOT cheaper
Does not need the reduction gear
And you probably don't need two
But it is a little less "sophisticated"
Discussion Starter · #32 ·
Here's an idea I was thinking about. I still have the output housing and shaft from the transmission. If I could modify it to mount to the electric motor and it would solve a lot of problems. Here's the issue with that:
The original set up fed ATF to keep the output shaft for lubrication.
What if I tapped the housing for grease fittings to pump grease into the areas in question? Would this even work?
The output shaft spins on a bronze bearing. If you seal the front of the tailshaft housing with your adapter plate, you might be able to get away with simply filling the tailshaft housing with ATF. The trans I rebuilt last summer actually used the tailshaft housing as an ATF reservoir in addition to the pan. Alignment of the motor/shaft and that rear bearing will be interesting.
· Administrator
That sounds to me to be VERY VERY DIFFICULT - and with no advantages
Does not need the reduction gear...
Yeah, Tesla's motors must be really wimpy, since they seem to need that 12:1 ratio two-stage reduction. :rolleyes:
You can productively use a greater reduction ratio than existing in the final drive if your motor can turn more than a few thousand rpm. If you're using century-old technology with brushes that don't let the motor turn as fast as an economy car's engine, then you use a really big motor at low speed, and the stock final drive ratio works well.
In looking at alternatives for my Spitfire, I concluded that if I were to convert it, I would want to keep the existing final drive and to eliminate any other transmission (so it would be configured like the plan for this project). I have considered the Chevrolet Spark EV motor, because it was designed to be used with only one stage of reduction gearing... and while it is built with the same technology as the Chevrolet Bolt motor, the slower Spark EV motor is substantially bigger and heavier while capable of producing less power. That's the price of slow motor operation, but if your type of motor can only turn slowly, then maybe that's not a problem.
What you are talking about doing is essentially duplicating NetGain's TransWarP motors, which are the same as their WarP motors (which are generic brushed series DC motors like those from an old forklift), but with a splined shaft end and added tailshaft housing. For lubrication, they only add grease fittings for the slip joint... but the output spline is on the motor shaft, so they're not adding or needing to support an extra shaft section, and larger sizes (9" and 11") have upgraded output-end bearings to handle the radial load.
If you must use a common motor without a splined output compatible with a sliding yoke for the propeller shaft, and your motor speed doesn't call for additional reduction gearing, a simple U-joint yoke and a propeller shaft with a sliding section (as Duncan suggested) is certainly the straightforward solution.
AC or DC is hardly the point. Also, I just looked and a 70 bhp AC motor is $2,900 and a 58 bhp DC motor (warp 11) is $3,200. Close enough that no-one is a LOT cheaper.
My point/question (because of the type of the cars) was about total bhp and total torque. I'll happily take any advice I can get, I'm not interested in measuring wimpiness or sophistication. This is an engineering puzzle so let's stick to the numbers.
I'm trying to match driving behavior. Like accelerating from 65 to 80 mph to over-take Elmer Fudd in his pick-up truck. For that, things should be close to original (I think).
The original engine had 430 ft lbs of torque and 325 bhp @ 51% rating (at 4,000 rpm). Alright, so be it, and those are the numbers I need to match to get to comparable performance.
One DC Warp 11 is ~55kW, so two of them is 110 kW / 0.7 = 160 bhp. The original had 51% of 325 = 170 bhp at the drive shaft, so I'm pretty close (within 10%).
One DC Warp 11 has 140 ft lbs. I need 430, so 3x what one Warp 11 can do. So, take 2 Warp 11's and a helical gear = 2 x 140 x 1.7 = 475 ft lbs. Again, a little better, but not a lot (10%).
Sure, I should get all my torque at 0 rpm / start-up and all that, but I'm building a road-car, not a drag racer. To me the numbers say 2 motors and a gear. If there's a hole in these numbers then let's discuss. What am I missing in this?
Yes, I went with AC because of what I had available, and my motors actually get about 100 bhp and 200+ ft lbs each so I should have a zippier car than what it was originally. Then again, the original was hardly a street racer plus this is the US so it's not going to help with speed-limits of 65 and 70 mph :)...
· Administrator
Hi Rob kr
I paid $100(NZ) form my first Hitachi 11 inch motor
The latest one I bought (as a spare) cost me $200
THAT is the cost of DC motors - and I'm pushing 1200 amps and 340 volts - 500 hp
You are comparing that to a limp wristed 70 hp at 15 times the cost!
AND the AC motor will need a controller that is a lot more expensive than a P&S
Modern OEM AC motors are GREAT
Aftermarket AC motors are wimpy and expensive
21 - 40 of 63 Posts
