I'll make a video after Wednesday when I get mine.
I believe they let the juice go till the battery gets to it "full" voltage, then it starts shunting or bypassing current. Once all of them are fully charged, it sends a signal down the looped wire (between every BMS module) to shut the charger off.
This is only a guess... I bought one cell balancer from ???? it has red and green LEDs that show you whats going on, but I didn't trust it to shut off my charger- I could be wrong. At least I know the MINI BMS will.
(Don't yell at me, I know the Mini BMS guy is gonna see this)
Also, since I only had the one BMS module from ???? I used it on my one battery I bought before I bought my set. It had charged faster than the rest, (I had wired them in parallel for almost a week and tried to charge them) making me wonder if the other batteries are used. Now, I have that battery plus one other charging faster than the rest, and once they break past 3.6 or so, they go fast to overcharged. So I'm done driving till my MINI BMS's show.
The one module by itself did drain off the excess voltage, but its not a fast function. I had to turn the charger off, and it took a while before the red LED turned off.
