Ultimate EV drive system 2 Siemens 1PV5138 & Inverters CA,LA
Two Siemens 1PV5138-4WS24 ELFA Drive Motors
Brand new, still on their original pallets these liquid cooled monsters were designed to propel a full size bus. These particular motors were purchased from Azure Dynamics when the company closed. They have the long output shaft that can be directly connected to a drive shaft. Liquid cooled these are the best of the best.
At 300 amps these are rated to 391 ft lbs of torque.
This is a high voltage system, rated to 10,000 rpm.
https://www.industry.usa.siemens.co...ive/Documents/elfa-components-data-sheets.pdf
I have eight inverter drivers, liquid cooled they are rated to 350 amps. Four of the inverters were never hooked up, installed as a redundancy system. Four have a blown igbt in the regenerative circuit, 3 for motor and 1 back to battery.
Would like to sell as a package, any interest?
They would require a DICO Vehicle Interface or maybe:
http://www.thunderstruck-ev.com/vcu-for-uqm-motors-new-item.html
I also have a 1992 Toyota MR2 for sale
https://losangeles.craigslist.org/lac/cto/6601770234.html
