Hi, this motor is not really made for low Voltage/ low RPM as you can see in the datasheet http://media3.ev-tv.me/Azure300VDC-400Acurve.pdf.Does anyone have experience with using the 'low voltage' Siemens motors on an even lower voltage?
Using the Siemens 1PV5135-4WS14 with a small controller (Sevcon? Curtis? ...?) on 48, 72 or 96 volt, what kind of output is to be expected?
If I'd want to get 10 or 20 kW continuous...as low rpm as possible... (small boat conversion)
The DMOC controllers need a 144 volt battery (minimum voltage during use 100 volt, start up voltage 120 volt), so not exactly 'low voltage'
Due to the availability of 48v charger / DC-AC inverters 48 volts would be ideal...but what's left of performance then...
But it can be used for 96V, then it would deliver about 10-20 kW continuous with about 100-200A. The motor frequency would still be about +/- 1000 RPM ( 16 Hz) . So you would need a reduction gearbox for your boat. Not sure Sevcon /Curtis - controllers will be able to work with this motor but some options are mentioned in http://www.diyelectriccar.com/forums/showthread.php/siemens-1pv5135-4ws14-83007p1.html.
http://www.hec-drives.nl/ has also an inverter (400 V) and a reduction gearbox.
