144 volt system going with old school CALB. Read a lot about how to convert my NG3 to lithium.
Probably best I send it off and let someone else do that.
Can someone recommend a BMS that has worked well for them using CALB.
Reliable low tech blinking light will work. On the high tech end,
BMS hooked to I-pad to actively monitor each cell. (don't know if that is possible)
Reference links on where to send charger and links for BMS would be great.
Thanks you for your help.
My Daughter loves her EV
