Hi,
I am not an engineer and still an amateur at electronics in general. I am trying very hard to catch up, so please excuse any forms of ignorance.
The point of this generator is to power my motor and charge the batteries while I drive. I am still working out how to connect it ( any advice appreciated) but this topic has to do specifically with upconverting the generators motor output to be effective for my purpose. It will in essence be a series hybrid while the generator is hooked up. ( Only for a few months until I can upgrade my batteries to lithium)
The 30 volts is DC (corrections 30 volts not 32 as the title says).
I am assuming that at 30V 500amps the current isn't going to be very usable by the controller; nor will it charge the batteries. If this isn't the case and it can still be an effective option please let me know.
I am trying to use a motor I have that is 15kw (30V @ 500amps).
My question is, can I convert it to 72 Volts? Or will it suffer too much loss at these amps?
If its possible I would appreciate any guidance. Building something is perfectly doable if I can find a decent schematic.
Thanks
Thanks
