UPDATE: We recently completed the retrofit of the AO3 transmission to the Net Gain Warp 11” DC Motor.
http://www.fbperformance.com/viewtrans.asp?TransmissionID=101
We were able to use all of the same Adapter components that we’ve been using for the 9” Warp motor. (See photos attached to the opening post). This is because the larger motor uses a face plate which is very similar in design and the output shaft has the same diameter.
This EV conversion is going to be used in a 1987 GM Panel truck with an estimated weight of 10,000lbs. For that reason we used the Low gear Planetary Set with a 2.84 first gear ratio. This ratio in combination with the 4.11 rear axle ratio and the high torque at low motor rpm will provide the desired movement of this vehicle at low speed.
As soon as we get some installation photos I’ll add them to this thread.
