Updates
Yesterday the motor arrived - Warp 9. Yeah, costs more than a forklift motor (but not much more, I got it shipped for 1k). However, how much is it worth to have it work? It spins, plus there are technical drawings and performance data. So far looking good.
The motor came with some handy parts - a taper lock (Quick Detachable Variant) on the drive end with the accompanying hub to squeeze the tapers. Saved me 50 dollars. It also came with an RPM sensor on the non drive end as well as a mounting plate - don't think I'll need it but it sure made it easier to move around.
I bought the manual transmission output shaft a few days ago - it comes tomorrow. The idea is to cut off the relevant spline bit of the output shaft and weld it into the taper lock. Then I can taper lock the male spline that will go into the driveshaft onto the motor.
This is the "Sled". It will be mounted in front to the motor mounts and at the rear to a beam that will get welded to the bottom of the car.
I screwed a piece of wood that is in the spot where the welded cross beam will be. I laid the 1.5" sled rails down as well as the PPF - it will be lopped off at the appropriate length and bolted to the sled, similarly how it used to be attached to the transmission.
Hopefully I can be ready to start welding next week.
