So I bought myself a motor.
Specs:
- UQM 135 model SPM195-114-3.
- Brushless PM
- 135 KW peak power
- 340 N/m / 251 Lb/ft peak torque up to 2500 RPM
- 8000 RPM limit
- 270 - 425 Vdc (inverter input)
- 400A peak (inverter input)
- 50 Kg / 110 Lb
- 94% peak efficiency
My plans are to make controller for it, and use it to drive honda civic type car. Does anyone know of a good method to test magnet force to make sure this motor is not de-magnetized? I am thinking to attach lever with weight on the end to the shaft and apply known current to one of the phases and determine torque per amp. I need to determine if stator wired in delta or wye. Below are some pictures comparing this motor to AC24LS from Azure.
Specs:
- Brushless PM
- 135 KW peak power
- 8000 RPM limit
- 50 Kg / 110 Lb
