Hi all,
I am researching a possible Ural conversion. For those that are unfamiliar with Urals, they are a motorcycle with a factory attached sidecar, and even have an option for 2 wheel drive. My plan would be to keep the transmission, drive shaft, final gear, and 2wd connections intact and replace the stock engine with an electric motor.
Unfortunately, I have been unable to find any detailed Ural conversions to use as a template so I am reaching out to you all for help.
Details on Urals
Stock weight: ~725 lbs
Engine weight: ~125 lbs
Estimated max weight: 1500 lbs
Final gear ratio 14.3:1
Desired sustainable speed: 60 mph
Desired range for initial build: 35 miles
My estimated max weight is with a motor, batteries, driver, an adult passenger, youth passenger, and enough gear to go camping for 2-3 nights. I have no doubt that it will be less than this but I am going to estimate on the heavy side just to be safe.
I plan to do this built in a few main stages that will probably be changed as the build goes on!
Stage 1: Get it running with the easiest solution possible, so probably some sort of kit
Stage 2: Add batteries from a Leaf, Volt, or other wrecked EV
Stage 3: Add a gas generator to increase range some but really to recharge away from an outlet
Stage 4: Add solar and/or micro wind generator to top off the batteries while I am at work.
So, here are my questions.
I am considering the following motor kit. I realize it is very expensive but I like the idea of plug and play for my very first EV build. So would this motor with the 96V setup be strong enough to maintain 60mph on a hilly road?
PMAC 15kW Cont. / 38kW Pk. Liquid-Cooled Motor Drive System 72/84V 550A
http://www.electricmotorsport.com/ev-parts/motor-drive-kits/pmac-15kw-cont-38kw-pk-liquid-cooled-motor-drive-system-72-84v-550a.html
The next piece would be the battery kit. Here are my questions:
Would the kit provide enough amps to maintain 55 mph?
Would it be possible to add additional non-standard batteries or would all of the batteries have to be exactly the same model number? Would home brewing battery packs from a used Leaf battery pack work?
Also, is it possible to change the amperage draw of the charger? For example, I would like it to be able to run off of a standard 110v 15A wall socket and also a 110v 30A RV outlet from a generator.
http://www.electricmotorsport.com/ev-parts/batteries/battery-packages/96v/gbs-96v-100ah-li-ion-battery-pack-with-emus-bms-and-charger.html
TLDR: will a PMAC 15kW Continous motor sustain 1500 lbs at 60 mph?
Thank you all for your help!
Details on Urals
