Ok guys, I have reached the 250th page, and I am going to add to this previous summary that I found
I will add, motors with
female splines are not easy to couple to your drivetrain, and the consensus among the experts is to not use them. Hence the comment above on the
drive motor being prefered: it will likely have a male shaft, be variable speed, be reversable from the outside of the case (so that it can be matched to the direction your transmission turns), and be heavier duty (1 hr continuous duty cycle at its rated power - it will handle much more for shorter bursts).
Regen is hard to implement with DC motors, and probably not worth the hassle.
Also, the easiest motor type to use is going to be
series wound, which can be identified by
4 large terminal posts on the outside of the case, likely marked A1/A2 F1/F2(or S1/S2). A multimeter will read nearly zero resistance across these sets, as they will have very heavy windings. Smaller electrical connectors can be brush-wear-indicators, or temperature probes, not all motors will have them.
SEP-EX or
separately excited motors are more complicated, but can be used with the right controller (do your homework before going this route). They will have smaller windings for one pair of terminals - so looking at the coils on the inner sides of the case (stators), expect to see copper wires the size of pencil leads. There will be a measurable resistance on these posts, and the terminals may be smaller.
Shunt wound will have 3 sets of terminals, 2 with low resistance, and 1 that reads higher like a sep-ex. Maybe not the best choice for a complete beginner.
Advancing brushes is done by removing the commutator end of the motor and re-drilling the holes to allow for the new position. You can tell that a motor has neutral timing by checking to see that the brushes line up with the center of the stator coils.
Bring a multimeter to check the resistance of the coils, and that there is not an electrical path from the studs to the case.
Plan on doing a
12 volt test: bring a 12 volt battery, jumper cables, and a third jumper of some sort. You will need to bridge either of the A terminals to either of the S terminals, and then connect your battery to the remaining studs. Swapping one of the jumpered studs reverses the direction.
If the forklift motor is still attached, have a look at post #2478 - it will give you an idea of what you might be up against.
Also, I want to give a huge shout-out to the experts that made this thread into the diamond mine that it is (you know who you are
) Hopefully I have not added too much to the overburden!
