I pulled an electric motor, complete with its gear box and electronic brake from a golden mobility scooter, which I found from Facebook Marketplace. I tested it and it seems to work fine, rotates in both directions.
The label on the motor is torn but the part number I found shows that it's an ASI Technologies Part number 10517, which leads me to believe it's this motor.
The riding mower I am using is the John Deere RX73. It was free from next door neighbor. The current engine is 9HP Kawasaki 290cc, it runs OK, it smokes a bit but it does run and mower moves fine, and deck engages.
This is my first conversion. My education and work is in software engineering and robotics, so I am probably one or two notches past newbie but not very far.
Looking online at previous examples of mower conversions, they all recommend to use a separate motor for the mower deck, which makes perfect sense. So then the scooter motor would just have to drive the tractor.
I have many, many questions but I'll start with just a couple:
1. What calculations can I do to have an idea of whether this motor will be powerful enough to drive the mower. Based on the datasheet, I see that at Heavy load, it can produce 58 ft-lbs of force, with 114 RPM's, so does that mean it only has (58 * 114) / 5252 = 1.25 HP? Will that be enough to drive the mower (without the deck)?
2. I have not yet done the exact measurement, but it looks like the transaxle from the gear box (meaning the distance between the wheels on the scooter) is shorter than the width between the two wheels on the mower. I don't have welding equipment but I have used jb weld epoxy many times. Assuming it really is shorter, what are my options?
Thanks in advance!
Sameh
Thanks in advance!
Sameh
