1 - 2 of 2 Posts
Is it possible to use a small Elevator motor in an EV conversion? I live in a country where forklift motors, especially electric ones, are hard to come by, so I've recently been looking into alternatives. Price aside, are elevator motors usable for EV conversions?
I have a link to some datasheets for these motors, here: https://nagel.com.tr/wp-content/uploads/NAGEL-MAKINE-MOTOR-URUN-KATALOGU-TR-EN.pdf
But if it opens into a pdf, this link also works, the catalog is at the very bottom. HOME
Thank you so much!
Discussion Starter · #2 ·
Also, I have a list of datasheet for different DC motors, which Im trying to compare to the netgain Warp-9.
Unfortunately, While the Warp-9 datasheet lists varying (80+ amps) amperages at a fixed 72 volts, The motor I'm comparing only has High voltages with low amperages (9-10A) listed. Is there a way to compare these 2 datasheets to check for viability in an EV conversion?
Thanks!
(https://www.femsan.com/docs/K.09.15.pdf vs https://www.go-ev.com/images/003_16_WarP_9_SpreadSheet.jpg)
1 - 2 of 2 Posts
