Has anyone used a camera to monitor their battery charger?
My charger pulls about 12 amps while charging, and about 10% of that while 'off'. If I leave it plugged in from get home to leave home that's ~16 hours, with the charge taking 7-8, so the majority of the time it's not doing anything useful, but is pulling over an amp continuous anyway.
I'm planning to install a dedicated charging circuit and would like to make a switch to turn off the charger from inside the house, and need a means of viewing the charge status also from inside. It could be incredibly low resolution as I just need to be able to recognize a charge percentage or 'CC'.
Any good (relatively easy/cheap) solutions out there?
Wireless would be preferred, but is not required (I can plug in a cat5 or coax along with the charging cord).
