Does anyone know what a safe bulk charge rate is for Volt modules? My Russco charger can output 23 amps or so, but I'm reluctant to charge the Volt pack higher than about 18 amps as the car only charges at 16 amps on level 2. Also I don't have the cooling system done yet.
I got the battery pack in the truck tonight and took it for a drive. Huge difference from lead batteries! I don't expect a lot of range with only 12 kw but for what I use the truck for it will be fine. The pack felt cool, after the drive and during charging. It was about 31 deg. F.
